[petsc-dev] git problem
Wed Feb 26 14:28:52 CST 2014
   I know if I do this I will get yelled at!  So why does git suggest something that will get me yelled at, why doesn’t it suggest something that will make Jed happy? I’m serious
   BTW: what the f am I suppose to do here.
   Barry
To git at bitbucket.org:petsc/petsc.git
 ! [rejected]        next -> next (fetch first)
error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
hint: Updates were rejected because the remote contains work that you do
hint: not have locally. This is usually caused by another repository pushing
hint: to the same ref. You may want to first merge the remote changes (e.g.,
hint: 'git pull') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
