[petsc-dev] DMPlexCreateExodus directly from file
Tue Feb 25 09:41:34 CST 2014
On Feb 25, 2014 9:48 AM, "Michael Lange" <michael.lange at imperial.ac.uk>
wrote:
> Hi,
> I keep hitting problems in my application code when I try to read in
ExodusII meshes via DMPlex due to the exodus libs installed on my system. I
can get around those simply by adding adding the ex_open() call required to
get the exoid directly to DMPlexCreateExodus(). This solution works great
with the ExodusII version PETSc downloads during configure and also makes
the DMPlex-ExodusII interface self-contained, which means that I do not
have to link my application code against exodus libs at all. The same
argument applies to the DMPlex-CGNS interface.
> So, I would like to prepare a pull request to make the ExodusII (CGNS)
interface self-contained, and I can see two ways to do this:
> a) Add the ex_open() call to DMPlexCreateExodus() and change the
interface to use the file name directly
> b) Add a utility function DMPlexCreateExodusFromFile() which calls
ex_open and then invokes DMPlexCreateExodus() as before
> Please tell me what you think and which way you prefer, and I will
provide a pull request to implement this.
I like b). Very often users want to control their own files. Note that you
can make the ex_open() call without appealing to your system since PETSc
has already linked it.
   Matt
> Kind regards,
> Michael Lange
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140225/b66a1a6e/attachment.html>
