[petsc-dev] DMPlexCreateExodus directly from file
Michael Lange michael.lange at imperial.ac.uk
Tue Feb 25 08:48:07 CST 2014
I keep hitting problems in my application code when I try to read in
ExodusII meshes via DMPlex due to the exodus libs installed on my
system. I can get around those simply by adding adding the ex_open()
call required to get the exoid directly to DMPlexCreateExodus(). This
solution works great with the ExodusII version PETSc downloads during
configure and also makes the DMPlex-ExodusII interface self-contained,
which means that I do not have to link my application code against
exodus libs at all. The same argument applies to the DMPlex-CGNS interface.
So, I would like to prepare a pull request to make the ExodusII (CGNS)
interface self-contained, and I can see two ways to do this:
a) Add the ex_open() call to DMPlexCreateExodus() and change the
interface to use the file name directly
b) Add a utility function DMPlexCreateExodusFromFile() which calls
ex_open and then invokes DMPlexCreateExodus() as before
Please tell me what you think and which way you prefer, and I will
provide a pull request to implement this.
Kind regards,
Michael Lange
