[petsc-dev] [mpich-discuss] turning off MPI abort messages
Jeff Hammond jeff.science at gmail.com
Fri Feb 21 22:47:43 CST 2014
Jed,
Did you look at my patch or the demonstration yet? I posted all the details this afternoon.
I tried very hard to support verbosity suppression in a reasonable way at runtime.
Do you really want an MPIX call that is equivalent to setenv("<see patch>")? Is the extra code worth it? (These are serious questions.)
Jeff
Sent from my iPhone
> On Feb 21, 2014, at 1:33 PM, Jed Brown <jed at jedbrown.org> wrote:
> Jim Dinan <james.dinan at gmail.com> writes:
>> Barry,
>> Do you need a portable solution that works across different MPI
>> implementations,
> This is well outside the standard so I don't see this being viable.
>> or does a solution for making just MPICH silent address your need?  If
>> the latter, you could probably convince someone on the MPICH team to
>> add an environment variable for MPICH and a command-line "quiet" flag
>> for hydra/mpiexec.
> Even better would be an MPIX_Set_error_verbosity() or MPIX_Abort_quietly().
> discuss mailing list     discuss at mpich.org
> To manage subscription options or unsubscribe:
> https://lists.mpich.org/mailman/listinfo/discuss
