[petsc-dev] [mpich-discuss] turning off MPI abort messages
Jed Brown jed at jedbrown.org
Fri Feb 21 13:33:25 CST 2014
Jim Dinan <james.dinan at gmail.com> writes:
> Barry,
> Do you need a portable solution that works across different MPI
> implementations,
This is well outside the standard so I don't see this being viable.
> or does a solution for making just MPICH silent address your need?  If
> the latter, you could probably convince someone on the MPICH team to
> add an environment variable for MPICH and a command-line "quiet" flag
> for hydra/mpiexec.
Even better would be an MPIX_Set_error_verbosity() or MPIX_Abort_quietly().
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140221/a8dbaedc/attachment.sig>
