[petsc-dev] [mpich-discuss] turning off MPI abort messages
Jeff Hammond jeff.science at gmail.com
Fri Feb 21 15:10:55 CST 2014
Barry:
Would the following behavior be acceptable to you?  I have only made
the changes in MPI but am looking at the process manager now.
Jeff
# Without the process manager
alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=0
alcfwl181:build jhammond$ ./a.out
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
alcfwl181:build jhammond$ export MPIR_CVAR_SUPPRESS_ABORT_MESSAGE=1
alcfwl181:build jhammond$ unset MPIR_CVAR_SUPPRESS_ABORT_MESSAGE
# With the process manager
alcfwl181:build jhammond$ mpiexec -n 1 -env
MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 0 ./a.out
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 61023 RUNNING AT alcfwl181.alcf.anl.gov
=   EXIT CODE: 1
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
MPIR_CVAR_SUPPRESS_ABORT_MESSAGE 1 ./a.out
=   PID 61026 RUNNING AT alcfwl181.alcf.anl.gov
=   EXIT CODE: 1
alcfwl181:build jhammond$ mpiexec -n 1 ./a.out
=   PID 61032 RUNNING AT alcfwl181.alcf.anl.gov
=   EXIT CODE: 1
On Thu, Feb 20, 2014 at 11:33 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Is there any way to turn off MPICH (and others) printing messages about MPI_Abort?  We have already prepared and presented useful error messages to the user about the situation and would like to avoid having these additional messages printed (that often make the situation look worse than it is)
>     Thanks
>    Barry
> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> [cli_0]: aborting job:
> ==================================================================mailto:discuss at mpich.org=================
> =   EXIT CODE: 56
> discuss mailing list     discuss at mpich.org
> To manage subscription options or unsubscribe:
> https://lists.mpich.org/mailman/listinfo/discuss
Jeff Hammond
