[petsc-dev] [mpich-discuss] turning off MPI abort messages
Fri Feb 21 13:10:20 CST 2014
~/Src/petsc/src/snes/examples/tutorials  barry/fix-petsc $ grep joe ex1.c
~/Src/petsc/src/snes/examples/tutorials  barry/fix-petsc $ echo $?
1
Well jeepers I just make grep “CRASH”.  A nonzero return code denotes some condition, it doesn’t denote a crash.
  Barry
On Feb 21, 2014, at 12:19 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
>>> Just configure MPICH such that snprintf isn't discovered by configure
>>> and you won't see these messages.
>>> The other solution is to fix PETSc so that people can't crash it so easily ;-)
>>   Here we go again. It is not CRASHING; it has detected an error conditioning and trying to appropriately and cleanly terminate. The reason it needs to use MPI_Abort() is that often detecting error conditions is not a uniformly collective thing.
>>    Printing a suitable error message and ending is not crashing. But with all the badly formatted “error messages” printed by MPICH I can not control at the end it looks like it is crashing.
> You're returning a non-zero exit code, which I consider crashing.  I
> apologize if this definition disagrees with yours.  If this is just
> gentle cleanup, why not exit with code=0 as Jim suggested already?
> Jeff
>>> On Thu, Feb 20, 2014 at 3:19 PM, Jim Dinan <james.dinan at gmail.com> wrote:
>>>> If you can find a way to call MPI_Finalize instead, you will portably
>>>> eliminate these messages.
>>>> A lesser solution would be to provide an error code of 0 (or MPI_SUCCESS) to
>>>> MPI_Abort, e.g. MPI_Comm_abort(MPI_COMM_WORLD, MPI_SUCCESS).  This would
>>>> eliminate the error message that you are getting from the job launcher.
>>>> MPICH could be modified to be quiet about the abort when the application
>>>> aborts with an error code of MPI_SUCCESS.
>>>> ~Jim.
>>>> On Thu, Feb 20, 2014 at 12:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>  Is there any way to turn off MPICH (and others) printing messages about
>>>>> MPI_Abort?  We have already prepared and presented useful error messages to
>>>>> the user about the situation and would like to avoid having these additional
>>>>> messages printed (that often make the situation look worse than it is)
>>>>>   Thanks
>>>>>  Barry
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
>>>>> [cli_0]: aborting job:
>>>>> ==================================================================mailto:discuss at mpich.org=================
>>>>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>> =   EXIT CODE: 56
>>>>> =   CLEANING UP REMAINING PROCESSES
>>>>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>> _______________________________________________
>>>>> discuss mailing list     discuss at mpich.org
>>>>> To manage subscription options or unsubscribe:
>>>>> https://lists.mpich.org/mailman/listinfo/discuss
>>> Jeff Hammond
> Jeff Hammond
