[petsc-dev] TaoTerminationReason -> TaoConvergedReason
Jed Brown jed at jedbrown.org
Tue Feb 18 09:22:52 CST 2014
Lisandro Dalcin <dalcinl at gmail.com> writes:
> Barry, I've pushed a quick fix (missing PETSC_EXTERN in TaoMonitor())
> in your branch.
> The following prototypes in petsctao.h are also missing PETSC_EXTERN,
> and I think they should be more properly namespaced.
> PetscErrorCode VecGetSubVec(Vec, IS, PetscInt, PetscReal, Vec*);
> PetscErrorCode MatGetSubMat(Mat, IS, Vec, TaoSubsetType, Mat*);
> Perhaps you should move these prototypes (as well as TaoSubsetType) to
> taoimpl.h ? I'm not sure these routines should be part of the public
> interface.
I would rather not, but if nothing else changes, the PetscInt argument
should be TaoSubsetType.  I'm afraid I don't understand exactly what
role this function is serving, but the only TAO reference is the enum,
so it can probably be made generic and moved down to the Vec module.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140218/357e305c/attachment.sig>
