[petsc-dev] TaoTerminationReason -> TaoConvergedReason
Lisandro Dalcin dalcinl at gmail.com
Tue Feb 18 03:43:01 CST 2014
Barry, I've pushed a quick fix (missing PETSC_EXTERN in TaoMonitor())
in your branch.
The following prototypes in petsctao.h are also missing PETSC_EXTERN,
and I think they should be more properly namespaced.
PetscErrorCode VecGetSubVec(Vec, IS, PetscInt, PetscReal, Vec*);
PetscErrorCode MatGetSubMat(Mat, IS, Vec, TaoSubsetType, Mat*);
Perhaps you should move these prototypes (as well as TaoSubsetType) to
taoimpl.h ? I'm not sure these routines should be part of the public
interface.
On 17 February 2014 23:16, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 17, 2014, at 2:17 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> What's your opinion about renaming TaoTerminationReason -> TaoConvergedReason ?
>   Done. Also for TaoLineSearchTerminationReason
>> Lisandro Dalcin
>> CIMEC (UNL/CONICET)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> 3000 Santa Fe, Argentina
>> Tel: +54-342-4511594 (ext 1016)
>> Tel/Fax: +54-342-4511169
Lisandro Dalcin
CIMEC (UNL/CONICET)
