[petsc-dev] tao4py and tao in PETSc master
Lisandro Dalcin dalcinl at gmail.com
Sun Feb 16 13:37:45 CST 2014
This branch contains what is needed to expose TAO within petsc4py:
https://bitbucket.org/petsc/petsc4py/branch/dalcinl/tao
Two comments/requests for TAO in petsc-dev:
* I would like to have TaoGetConstraintTolerances(), right now I'm
defining it in petsc4py as shown in the link below:
https://bitbucket.org/petsc/petsc4py/commits/ab01ebe336491190a2db85c179c48b1c64fdc673?at=master#chg-src/include/custom.h
* Look at all these definitions, they should be exposed in the C API
to be able to call e.g. TaoSetType(tao,TAOLMVM);
https://bitbucket.org/petsc/petsc4py/commits/ab01ebe336491190a2db85c179c48b1c64fdc673?at=master#Lsrc/PETSc/petsctao.pxiT4
Final comment: I've named the solver "TAO" (all uppercase) in
petsc4py. This deviates from the current PETSc convention using "Tao",
but I'm thinking that at some point you will get upset with the
inconsistency and rename it to TAO.
Let me know what you think. After merging this branch, "tao4py" should
die and the functionalities will be available directly from petsc4py.
On 15 February 2014 01:08, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 12 February 2014 18:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Lisandro,
>>     Now that tao is a subdirectory in the PETSc package (currently in master) and behaves “just like” other parts of PETSc will you be updating Tao4py? With the reorganization of Tao into PETSc I think this should even simplify Tao4py.
> I'm still not sure what to do. Perhaps I should just add the TAO
> features to petsc4py directly? Anywat, I'll first update tao4py to
> work with TAO in petsc-dev.
>>    Let me know if there is anything broken in my reorg of Tao into PETSc.
> I'll do once I have some free slots to work on it.
> Lisandro Dalcin
> CIMEC (UNL/CONICET)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> 3000 Santa Fe, Argentina
> Tel: +54-342-4511594 (ext 1016)
> Tel/Fax: +54-342-4511169
Lisandro Dalcin
CIMEC (UNL/CONICET)
