[petsc-dev] ts_monitor_solution_vtk does not work when used with DMComposite
Mani Chandra mc0710 at gmail.com
Fri Feb 7 16:09:08 CST 2014
Yeah, I have one DMDA for each variable in my system. I then put all these
in a DM. Do you think there's any other format I could use? Just need to
get the output to play nice with VisIt.
On Fri, Feb 7, 2014 at 3:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mani Chandra <mc0710 at gmail.com> writes:
> > Hi,
> > The command line option -ts_monitor_solution_vtk filename-%03d.vts does
> not
> > output anything when the DM used is a DMComposite. I checked that it
> works
> > when used with a DMDA. Possible bug?
> It has not been implemented.  Do you have multiple DMDAs?  The VTK
> format doesn't compose well so it's nontrivial to write multiple parts.
> (It could be done, but it would require several writing phases and
> capturing a lot of intermediate state; it will take some careful coding
> to implement and will be harder to understand.)  We either need to do
> that or choose a different output format.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140207/1a8efc34/attachment.html>
