[petsc-dev] ts_monitor_solution_vtk does not work when used with DMComposite
Mani Chandra mc0710 at gmail.com
Fri Feb 7 15:48:41 CST 2014
The command line option -ts_monitor_solution_vtk filename-%03d.vts does not
output anything when the DM used is a DMComposite. I checked that it works
when used with a DMDA. Possible bug?
Cheers,
Mani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140207/5e61cca7/attachment.html>
