[petsc-dev] [EXTERNAL] [pflotran-dev: 2700] Unintended consequence of CHKERRQ()
Gautam Bisht gbisht at lbl.gov
Wed Dec 3 14:13:56 CST 2014
The user function was putting NaNs in the residual vector. I ended up
fixing the user function to avoid putting NaNs in the residual vector.
-Gautam.
On Wed, Dec 3, 2014 at 10:48 AM, Jed Brown <jed at jedbrown.org> wrote:
> "Hammond, Glenn E" <gehammo at sandia.gov> writes:
> > Can you explain why the NaNs or infs are being produced in the first
> place, or at least pinpoint the location and catch it there?
> If the SNESFunction computes NaN because the state is invalid, please
> call SNESSetFunctionDomainError and don't update the residual vector (or
> don't put NaN in there).  SNES will clean up and return with
> SNESConvergedReason SNES_DIVERGED_FUNCTION_DOMAIN.
> We don't do this by default because detecting NaN collectively requires
> an extra reduction.  Perhaps SNES could have a mode that automatically
> checks.
> > Glenn
> > From: pflotran-dev at googlegroups.com [mailto:
> pflotran-dev at googlegroups.com] On Behalf Of Gautam Bisht
> > Sent: Wednesday, December 03, 2014 8:36 AM
> > To: pflotran-dev at googlegroups.com
> > Subject: [EXTERNAL] [pflotran-dev: 2695] Unintended consequence of
> CHKERRQ()
> > The issue is that when SNES diverges with a "not-a-number or infinite",
> the code crashes without giving timestepper_BE a chance to reduce the
> time-step. But, if CHKERRQ() is commented out after call to SNESSolve(),
> the code is able to reduce dt sufficiently to converge due to "itol_res"
> (PFLOTRAN's custom convergence reason == inorm_residual <
> solver%newton_inf_res_tol). Attached below is inputdeck (with an outrages
> initial dt = 1yr to illustrate the issue). Apart from commenting out
> CHKERRQ(), is there an alternate way to let timestepper_BE reduce dt?
> > Below are relevant information to reproduce the error.
> >>hg tip
> > changeset:   8541:fa2d4295aa14
> > tag:         tip
> > user:        Nathan Collier <nathaniel.collier at gmail.com<mailto:
> nathaniel.collier at gmail.com>>
> > date:        Wed Dec 03 08:52:00 2014 -0500
> > summary:     made output process-model identifier lines to be of uniform
> length (80 characters). Yeah it is a little OCD of me.
> >>./pflotran -pflotranin da.in<http://da.in>
> > == TH FLOW
> >   1 2f: 2.55E+00 2x: 1.63E+07 2s: 1.72E+07 ir: 1.49E+00 iu: 3.10E+06
> rsn:   0
> >   2 2f: 1.88E-01 2x: 1.57E+14 2s: 1.57E+14 ir: 5.33E-02 iu: 4.37E+13
> rsn:   0
> >   3 2f: 1.07E-01 2x: 1.60E+14 2s: 4.28E+12 ir: 2.27E-02 iu: 9.90E+11
> rsn:   0
> >   4 2f: 1.24E+01 2x: 1.60E+14 2s: 9.53E+11 ir: 1.16E+01 iu: 7.15E+11
> rsn:   0
> >   5 2f: 1.29E+06 2x: 7.75E+20 2s: 7.75E+20 ir: 1.15E+06 iu: 7.21E+20
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  1[  0] t=  0.00000E+00 dt=
> 5.00000E-01
> >   1 2f: 2.22E+00 2x: 1.38E+07 2s: 1.47E+07 ir: 1.47E+00 iu: 3.06E+06
> rsn:   0
> >   2 2f: 2.94E-01 2x: 1.11E+14 2s: 1.11E+14 ir: 1.44E-01 iu: 4.05E+13
> rsn:   0
> >   3 2f: 6.05E+20 2x: 2.13E+14 2s: 1.79E+14 ir: 4.44E+20 iu: 8.93E+13
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  2[  0] t=  0.00000E+00 dt=
> 2.50000E-01
> >   1 2f: 2.17E+00 2x: 1.12E+07 2s: 1.21E+07 ir: 1.44E+00 iu: 3.01E+06
> rsn:   0
> >   2 2f: 5.55E-01 2x: 8.08E+13 2s: 8.08E+13 ir: 4.07E-01 iu: 3.66E+13
> rsn:   0
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Floating point exception
> > [0]PETSC ERROR: Vec entry at local location 50 is not-a-number or
> infinite at end of function: Parameter number 3
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.5.1, unknown
> > [0]PETSC ERROR: ../../../src/pflotran/pflotran on a
> darwin-gnu-fort-debug named gautams-mac-pro.dhcp.lbl.gov<
> http://gautams-mac-pro.dhcp.lbl.gov> by gbisht Wed Dec  3 08:16:17 2014
> > [0]PETSC ERROR: Configure options --download-hdf5=1
> --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate
> --download-parmetis=yes --download-metis=yes
> --with-cc=/opt/local/bin/mpicc-openmpi-mp
> --with-cxx=/opt/local/bin/mpicxx-openmpi-mp
> --with-fc=/opt/local/bin/mpif90-openmpi-mp
> --with-mpiexec=/opt/local/bin/mpiexec-openmpi-mp
> PETSC_ARCH=darwin-gnu-fort-debug --download-sowing=1
> > [0]PETSC ERROR: #1 VecValidValues() line 34 in
> /Users/gbisht/Research/Models/PETSc/petsc_821a792/src/vec/vec/interface/rvector.c
> > [0]PETSC ERROR: #2 SNESComputeFunction() line 2043 in
> /Users/gbisht/Research/Models/PETSc/petsc_821a792/src/snes/interface/snes.c
> > [0]PETSC ERROR: #3 SNESLineSearchApply_Basic() line 40 in
> /Users/gbisht/Research/Models/PETSc/petsc_821a792/src/snes/linesearch/impls/basic/linesearchbasic.c
> > [0]PETSC ERROR: #4 SNESLineSearchApply() line 563 in
> /Users/gbisht/Research/Models/PETSc/petsc_821a792/src/snes/linesearch/interface/linesearch.c
> > [0]PETSC ERROR: #5 SNESSolve_NEWTONLS() line 254 in
> /Users/gbisht/Research/Models/PETSc/petsc_821a792/src/snes/impls/ls/ls.c
> > [0]PETSC ERROR: #6 SNESSolve() line 3743 in
> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> > with errorcode 72.
> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> > You may or may not see output from other processes, depending on
> > exactly when Open MPI kills them.
> >> hg diff
> > diff -r fa2d4295aa14 src/pflotran/timestepper_BE.F90
> > --- a/src/pflotran/timestepper_BE.F90           Wed Dec 03 08:52:00 2014
> -0500
> > +++ b/src/pflotran/timestepper_BE.F90       Wed Dec 03 08:22:35 2014
> -0800
> > @@ -310,7 +310,7 @@
> >      call PetscTime(log_start_time, ierr);CHKERRQ(ierr)
> >      call SNESSolve(solver%snes,PETSC_NULL_OBJECT, &
> > -                   process_model%solution_vec,ierr);CHKERRQ(ierr)
> > +                   process_model%solution_vec,ierr);!CHKERRQ(ierr)
> >      call PetscTime(log_end_time, ierr);CHKERRQ(ierr)
> > == TH FLOW
> rsn:   0
> rsn:   0
> rsn:   0
> rsn:   0
> rsn: max_norm
> 5.00000E-01
> rsn:   0
> rsn:   0
> rsn: max_norm
> 2.50000E-01
> rsn:   0
> rsn:   0
> http://gautams-mac-pro.dhcp.lbl.gov> by gbisht Wed Dec  3 08:17:35 2014
> >  -> Cut time step: snes=  0 icut=  3[  0] t=  0.00000E+00 dt=
> 1.25000E-01
> >   1 2f: 2.12E+00 2x: 9.08E+06 2s: 9.85E+06 ir: 1.41E+00 iu: 2.94E+06
> rsn:   0
> >   2 2f: 7.89E-01 2x: 5.95E+13 2s: 5.95E+13 ir: 6.28E-01 iu: 3.20E+13
> rsn:   0
> > [0]PETSC ERROR: Vec entry at local location 34 is not-a-number or
> > [0]PETSC ERROR: #7 VecValidValues() line 34 in
> > [0]PETSC ERROR: #8 SNESComputeFunction() line 2043 in
> > [0]PETSC ERROR: #9 SNESLineSearchApply_Basic() line 40 in
> > [0]PETSC ERROR: #10 SNESLineSearchApply() line 563 in
> > [0]PETSC ERROR: #11 SNESSolve_NEWTONLS() line 254 in
> > [0]PETSC ERROR: #12 SNESSolve() line 3743 in
> >  -> Cut time step: snes=  0 icut=  4[  0] t=  0.00000E+00 dt=
> 6.25000E-02
> >   1 2f: 2.04E+00 2x: 7.38E+06 2s: 8.06E+06 ir: 1.36E+00 iu: 2.86E+06
> rsn:   0
> >   2 2f: 5.60E+04 2x: 4.28E+13 2s: 4.28E+13 ir: 4.47E+04 iu: 2.66E+13
> rsn:   0
> >   3 2f: 1.16E+18 2x: 4.91E+13 2s: 2.30E+13 ir: 9.47E+17 iu: 1.69E+13
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  5[  0] t=  0.00000E+00 dt=
> 3.12500E-02
> >   1 2f: 1.94E+00 2x: 6.00E+06 2s: 6.57E+06 ir: 1.30E+00 iu: 2.74E+06
> rsn:   0
> >   2 2f: 6.76E+04 2x: 2.91E+13 2s: 2.91E+13 ir: 5.18E+04 iu: 2.06E+13
> rsn:   0
> > [0]PETSC ERROR: Vec entry at local location 14 is not-a-number or
> > [0]PETSC ERROR: #13 VecValidValues() line 34 in
> > [0]PETSC ERROR: #14 SNESComputeFunction() line 2043 in
> > [0]PETSC ERROR: #15 SNESLineSearchApply_Basic() line 40 in
> > [0]PETSC ERROR: #16 SNESLineSearchApply() line 563 in
> > [0]PETSC ERROR: #17 SNESSolve_NEWTONLS() line 254 in
> > [0]PETSC ERROR: #18 SNESSolve() line 3743 in
> >  -> Cut time step: snes=  0 icut=  6[  0] t=  0.00000E+00 dt=
> 1.56250E-02
> >   1 2f: 1.81E+00 2x: 4.84E+06 2s: 5.31E+06 ir: 1.21E+00 iu: 2.58E+06
> rsn:   0
> >   2 2f: 1.56E+04 2x: 1.81E+13 2s: 1.81E+13 ir: 1.22E+04 iu: 1.43E+13
> rsn:   0
> >   3 2f: 9.46E+15 2x: 1.99E+13 2s: 7.41E+12 ir: 7.34E+15 iu: 5.84E+12
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  7[  0] t=  0.00000E+00 dt=
> 7.81250E-03
> >   1 2f: 1.64E+00 2x: 3.85E+06 2s: 4.21E+06 ir: 1.11E+00 iu: 2.37E+06
> rsn:   0
> >   2 2f: 1.37E+04 2x: 9.82E+12 2s: 9.82E+12 ir: 1.02E+04 iu: 8.52E+12
> rsn:   0
> >   3 2f: 5.35E+14 2x: 1.86E+13 2s: 1.65E+13 ir: 3.78E+14 iu: 1.62E+13
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  8[  0] t=  0.00000E+00 dt=
> 3.90625E-03
> >   1 2f: 1.42E+00 2x: 3.01E+06 2s: 3.25E+06 ir: 9.67E-01 iu: 2.09E+06
> rsn:   0
> >   2 2f: 6.03E+03 2x: 4.39E+12 2s: 4.39E+12 ir: 4.38E+03 iu: 4.08E+12
> rsn:   0
> > [0]PETSC ERROR: Vec entry at local location 30 is not-a-number or
> > [0]PETSC ERROR: #19 VecValidValues() line 34 in
> > [0]PETSC ERROR: #20 SNESComputeFunction() line 2043 in
> > [0]PETSC ERROR: #21 SNESLineSearchApply_Basic() line 40 in
> > [0]PETSC ERROR: #22 SNESLineSearchApply() line 563 in
> > [0]PETSC ERROR: #23 SNESSolve_NEWTONLS() line 254 in
> > [0]PETSC ERROR: #24 SNESSolve() line 3743 in
> >  -> Cut time step: snes=  0 icut=  9[  0] t=  0.00000E+00 dt=
> 1.95312E-03
> >   1 2f: 1.16E+00 2x: 2.30E+06 2s: 2.42E+06 ir: 8.00E-01 iu: 1.76E+06
> rsn:   0
> >   2 2f: 4.32E+03 2x: 1.47E+12 2s: 1.47E+12 ir: 3.07E+03 iu: 1.42E+12
> rsn:   0
> > [0]PETSC ERROR: Vec entry at local location 4 is not-a-number or
> > [0]PETSC ERROR: #25 VecValidValues() line 34 in
> > [0]PETSC ERROR: #26 SNESComputeFunction() line 2043 in
> > [0]PETSC ERROR: #27 SNESLineSearchApply_Basic() line 40 in
> > [0]PETSC ERROR: #28 SNESLineSearchApply() line 563 in
> > [0]PETSC ERROR: #29 SNESSolve_NEWTONLS() line 254 in
> > [0]PETSC ERROR: #30 SNESSolve() line 3743 in
> >  -> Cut time step: snes=  0 icut= 10[  0] t=  0.00000E+00 dt=
> 9.76562E-04
> >   1 2f: 8.79E-01 2x: 1.73E+06 2s: 1.70E+06 ir: 6.11E-01 iu: 1.37E+06
> rsn:   0
> >   2 2f: 1.34E+03 2x: 3.17E+11 2s: 3.17E+11 ir: 9.30E+02 iu: 3.14E+11
> rsn:   0
> >   3 2f: 3.99E+13 2x: 6.13E+11 2s: 3.04E+11 ir: 3.26E+13 iu: 2.98E+11
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut= 11[  0] t=  0.00000E+00 dt=
> 4.88281E-04
> >   1 2f: 5.96E-01 2x: 1.33E+06 2s: 1.10E+06 ir: 4.19E-01 iu: 9.69E+05
> rsn:   0
> >   2 2f: 4.60E+04 2x: 3.54E+10 2s: 3.54E+10 ir: 3.25E+04 iu: 3.54E+10
> rsn:   0
> >   3 2f: 9.64E+15 2x: 3.91E+11 2s: 3.55E+11 ir: 7.87E+15 iu: 3.55E+11
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut= 12[  0] t=  0.00000E+00 dt=
> 2.44141E-04
> >   1 2f: 3.54E-01 2x: 1.11E+06 2s: 6.36E+05 ir: 2.50E-01 iu: 5.95E+05
> rsn:   0
> >   2 2f: 5.42E+04 2x: 1.33E+09 2s: 1.33E+09 ir: 3.93E+04 iu: 1.33E+09
> rsn:   0
> >   3 2f: 3.51E+06 2x: 1.75E+10 2s: 1.75E+10 ir: 2.87E+06 iu: 1.75E+10
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut= 13[  0] t=  0.00000E+00 dt=
> 1.22070E-04
> >   1 2f: 5.74E-02 2x: 1.04E+06 2s: 3.17E+05 ir: 4.02E-02 iu: 3.07E+05
> rsn:   0
> >   2 2f: 3.60E-02 2x: 6.66E+09 2s: 6.66E+09 ir: 2.88E-02 iu: 6.66E+09
> rsn:   0
> >   3 2f: 5.16E+02 2x: 2.91E+08 2s: 6.95E+09 ir: 3.31E+02 iu: 6.95E+09
> rsn:   0
> >   4 2f: 7.20E+04 2x: 7.65E+15 2s: 7.65E+15 ir: 6.73E+04 iu: 7.65E+15
> rsn:   0
> >   5 2f: 4.01E+12 2x: 3.15E+16 2s: 3.92E+16 ir: 3.27E+12 iu: 3.92E+16
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut= 14[  0] t=  0.00000E+00 dt=
> 6.10352E-05
> >   1 2f: 8.13E-02 2x: 1.04E+06 2s: 1.33E+05 ir: 8.02E-02 iu: 1.31E+05
> rsn:   0
> >   2 2f: 1.94E+02 2x: 1.14E+08 2s: 1.14E+08 ir: 1.33E+02 iu: 1.14E+08
> rsn:   0
> >   3 2f: 2.16E-01 2x: 4.22E+08 2s: 5.36E+08 ir: 1.79E-01 iu: 5.36E+08
> rsn:   0
> >   4 2f: 3.21E+28 2x: 1.07E+19 2s: 1.07E+19 ir: 2.62E+28 iu: 1.07E+19
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut= 15[  0] t=  0.00000E+00 dt=
> 3.05176E-05
> >   1 2f: 1.13E-05 2x: 1.05E+06 2s: 4.69E+04 ir: 1.13E-05 iu: 4.67E+04
> rsn:   0
> >   2 2f: 1.21E-10 2x: 1.05E+06 2s: 6.87E+02 ir: 1.05E-10 iu: 6.87E+02
> rsn: itol_res
> >  Step      1 Time=  3.05176E-05 Dt=  3.05176E-05 [y] snes_conv_reason:
>  10
> >   newton =  47 [      47] linear =    52 [        52] cuts = 15 [  15]
> >   --> SNES Linear/Non-Linear Iterations =            2  /            2
> >   --> SNES Residual:   1.209152E-10  1.209152E-12  1.045172E-10
> >   --> max chng: dpmx=   4.5981E+04 dtmpmx=   1.6500E+00
> > == TH FLOW
> >   1 2f: 1.62E-01 2x: 1.04E+06 2s: 7.34E+04 ir: 1.60E-01 iu: 7.27E+04
> rsn:   0
> >   2 2f: 7.18E+01 2x: 6.44E+07 2s: 6.44E+07 ir: 4.68E+01 iu: 6.44E+07
> rsn:   0
> >   3 2f: 2.52E-01 2x: 5.48E+07 2s: 1.19E+08 ir: 2.02E-01 iu: 1.19E+08
> rsn:   0
> >   4 2f: 1.29E+09 2x: 1.44E+18 2s: 1.44E+18 ir: 1.29E+09 iu: 1.44E+18
> rsn: max_norm
> >  -> Cut time step: snes=-10 icut=  1[ 15] t=  3.05176E-05 dt=
> 1.52588E-05
> >   1 2f: 3.23E-01 2x: 1.04E+06 2s: 3.15E+04 ir: 3.19E-01 iu: 3.13E+04
> rsn:   0
> >   2 2f: 1.17E-03 2x: 3.08E+06 2s: 2.83E+06 ir: 1.09E-03 iu: 2.83E+06
> rsn:   0
> >   3 2f: 3.23E-01 2x: 1.04E+06 2s: 2.83E+06 ir: 3.19E-01 iu: 2.83E+06
> rsn:   0
> >   4 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >   5 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >   6 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >   7 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >   8 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >   9 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  10 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  11 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  12 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  13 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  14 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  15 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  16 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  17 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  18 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  19 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  20 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  21 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  22 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  23 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  24 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  25 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  26 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  27 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  28 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  29 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  30 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  31 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  32 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  33 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  34 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  35 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  36 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  37 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  38 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  39 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  40 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  41 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  42 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  43 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  44 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  45 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  46 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  47 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  48 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  49 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  50 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  51 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  52 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  53 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  54 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  55 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  56 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  57 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  58 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  59 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  60 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  61 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  62 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  63 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  64 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  65 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  66 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  67 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  68 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  69 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  70 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  71 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  72 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  73 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  74 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  75 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  76 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  77 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  78 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  79 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  80 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  81 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  82 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  83 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  84 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  85 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  86 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  87 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  88 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  89 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  90 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  91 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  92 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  93 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  94 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  95 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  96 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  97 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> >  98 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  99 2f: 3.23E-01 2x: 1.04E+06 2s: 2.89E+06 ir: 3.19E-01 iu: 2.89E+06
> rsn:   0
> > 100 2f: 1.18E-03 2x: 3.14E+06 2s: 2.89E+06 ir: 1.10E-03 iu: 2.89E+06
> rsn:   0
> >  -> Cut time step: snes= -5 icut=  2[ 15] t=  3.05176E-05 dt=
> 7.62939E-06
> >   1 2f: 6.23E-01 2x: 1.04E+06 2s: 1.39E+04 ir: 6.15E-01 iu: 1.38E+04
> rsn:   0
> >   2 2f: 6.18E-04 2x: 1.06E+06 2s: 1.15E+05 ir: 5.25E-04 iu: 1.15E+05
> rsn:   0
> >   3 2f: 6.23E-01 2x: 1.04E+06 2s: 1.15E+05 ir: 6.15E-01 iu: 1.15E+05
> rsn:   0
> >   4 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >   5 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >   6 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >   7 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >   8 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >   9 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  10 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  11 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  12 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  13 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  14 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  15 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  16 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  17 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  18 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  19 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  20 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  21 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  22 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  23 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  24 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  25 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  26 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  27 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  28 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  29 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  30 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  31 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  32 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  33 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  34 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  35 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  36 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  37 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  38 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  39 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  40 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  41 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  42 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  43 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  44 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  45 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  46 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  47 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  48 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  49 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  50 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  51 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  52 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  53 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  54 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  55 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  56 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  57 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  58 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  59 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  60 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  61 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  62 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  63 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  64 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  65 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  66 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  67 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  68 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  69 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  70 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  71 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  72 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  73 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  74 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  75 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  76 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  77 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  78 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  79 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  80 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  81 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  82 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  83 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  84 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  85 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  86 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  87 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  88 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  89 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  90 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  91 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  92 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  93 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  94 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  95 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  96 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  97 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> >  98 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  99 2f: 6.23E-01 2x: 1.04E+06 2s: 1.16E+05 ir: 6.15E-01 iu: 1.16E+05
> rsn:   0
> > 100 2f: 6.18E-04 2x: 1.06E+06 2s: 1.16E+05 ir: 5.25E-04 iu: 1.16E+05
> rsn:   0
> >  -> Cut time step: snes= -5 icut=  3[ 15] t=  3.05176E-05 dt=
> 3.81470E-06
> >   1 2f: 8.15E-01 2x: 1.05E+06 2s: 6.36E+03 ir: 8.05E-01 iu: 6.33E+03
> rsn:   0
> >   2 2f: 1.34E-03 2x: 1.05E+06 2s: 4.20E+03 ir: 1.31E-03 iu: 4.19E+03
> rsn:   0
> >   3 2f: 4.65E-04 2x: 1.05E+06 2s: 2.99E+02 ir: 4.59E-04 iu: 2.50E+02
> rsn:   0
> >   4 2f: 1.43E-04 2x: 1.05E+06 2s: 1.18E+02 ir: 1.41E-04 iu: 1.18E+02
> rsn:   0
> >   5 2f: 4.35E-05 2x: 1.05E+06 2s: 8.37E+01 ir: 4.30E-05 iu: 8.37E+01
> rsn:   0
> >   6 2f: 1.27E-05 2x: 1.05E+06 2s: 5.80E+01 ir: 1.25E-05 iu: 5.80E+01
> rsn:   0
> >   7 2f: 3.26E-06 2x: 1.05E+06 2s: 3.69E+01 ir: 3.22E-06 iu: 3.69E+01
> rsn:   0
> >   8 2f: 5.57E-07 2x: 1.05E+06 2s: 1.83E+01 ir: 5.50E-07 iu: 1.83E+01
> rsn:   0
> >   9 2f: 2.98E-08 2x: 1.05E+06 2s: 4.65E+00 ir: 2.95E-08 iu: 4.65E+00
> rsn:   0
> >  10 2f: 9.92E-11 2x: 1.05E+06 2s: 2.79E-01 ir: 9.78E-11 iu: 2.79E-01
> rsn: itol_res
> >  Step      2 Time=  3.43323E-05 Dt=  3.81470E-06 [y] snes_conv_reason:
>  10
> >   newton = 214 [     261] linear =   214 [       266] cuts =  3 [  18]
> >   --> SNES Linear/Non-Linear Iterations =           10  /           10
> >   --> SNES Residual:   9.921423E-11  9.921423E-13  9.778422E-11
> >   --> max chng: dpmx=   1.6597E+03 dtmpmx=   1.9780E-01
> > You received this message because you are subscribed to the Google
> Groups "pflotran-dev" group.
> > To view this discussion on the web visit
> https://groups.google.com/d/msgid/pflotran-dev/CAPz1TnfKQJov5Uxvghp_31uKpxz0SdJ1XLV%3Dy2pt5gOrkY_CHg%40mail.gmail.com
> https://groups.google.com/d/msgid/pflotran-dev/CAPz1TnfKQJov5Uxvghp_31uKpxz0SdJ1XLV%3Dy2pt5gOrkY_CHg%40mail.gmail.com?utm_medium=email&utm_source=footer
> https://groups.google.com/d/msgid/pflotran-dev/92b8b510fceb47309cc0b8f7ada47ef4%40ES06AMSNLNT.srn.sandia.gov
> You received this message because you are subscribed to the Google Groups
> https://groups.google.com/d/msgid/pflotran-dev/87mw748t8f.fsf%40jedbrown.org
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141203/6d6b7439/attachment.html>
