[petsc-dev] workflow diagram
Wed Apr 30 19:51:48 CDT 2014
On Wed, 30 Apr 2014, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> > BTW: instead of associating 'discard when next is rewound' to the
> >> > dotted arrows - I'll suggest using the same 'merge' arrow notation here.
> >> I wanted to indicate which parts of the graph remain in permanent
> >> history and which parts are only temporary.  I changed 'next' to a
> >> dashed line to further reinforce this.
> >> > And then somehow show that the 'next branch is discared and
> >> > reconstruced (from master) at the next release..
> > Here is my attempt to show the release dynamics better..
> > https://docs.google.com/drawings/d/1kMHa7O6FB5iiJG5QPTWqlMne1xv17A6jOXXyQ_74kaE/edit?usp=sharing
> Hmm, feature releases are in first-parent history of both 'maint' and
> 'master'.  We tag a release on 'master', then do a fast-forward merge of
> the release tag into 'maint'.
Ok - updated.
Satish
