[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 19:45:14 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
>> > BTW: instead of associating 'discard when next is rewound' to the
>> > dotted arrows - I'll suggest using the same 'merge' arrow notation here.
>> I wanted to indicate which parts of the graph remain in permanent
>> history and which parts are only temporary.  I changed 'next' to a
>> dashed line to further reinforce this.
>> > And then somehow show that the 'next branch is discared and
>> > reconstruced (from master) at the next release..
> Here is my attempt to show the release dynamics better..
> https://docs.google.com/drawings/d/1kMHa7O6FB5iiJG5QPTWqlMne1xv17A6jOXXyQ_74kaE/edit?usp=sharing
Hmm, feature releases are in first-parent history of both 'maint' and
'master'.  We tag a release on 'master', then do a fast-forward merge of
the release tag into 'maint'.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/11024b6b/attachment.sig>
