[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 16:53:44 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>    It is pretty good. One thing that I don’t think is clear is that
>    the successful testing in next TRIGGERs the branch being merged up
>    to master. I have drawn in an ugly curve which is an example of
>    that. Sadly I couldn’t see how to put an arrow on it nor put text
>    saying something like “successful test leads to merge of branch
>    into master”.
I hoped that "merged with evidence of stability" communicated that part.
>    Also you use funky unnecessary language that muddles things up.
>     red circle — merge to integration branch “integration”? Just say
>     next/test branch in fact next should really be called test branch
>     but I guess we are stuck with next
Changed.
>    You waste too much of the page with all the explanation at the
>    bottom.
Hmm, I don't think I can expand the graph without making it more
confusing.  The legend at the bottom lets my comment more, but I'm sure
it can be tightened up more.
>    Make the maint and master branch lines blue, the feature lines
>    yellow, the bug fix branch line green, the next branch line red
Done
>    The wording (usually start from master) is wrong. It is the branch
>    that is usually started from master not the commit.
fixed
>    Remove all the business of “discard when next is rewound words”
>    instead just show the next release being made on the right side of
>    the picture and hence the new next being made again like you do at
>    the left side
I've tried that.
>    With these changes you can get rid of the last three things at the
>    bottom in ()
Hmm, I might wait on deleting that.  I'm not sure it's communicated by
the other part of the figure.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/25a56c1c/attachment.sig>
