[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 16:09:07 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> BTW: instead of associating 'discard when next is rewound' to the
> dotted arrows - I'll suggest using the same 'merge' arrow notation here.
I wanted to indicate which parts of the graph remain in permanent
history and which parts are only temporary.  I changed 'next' to a
dashed line to further reinforce this.
> And then somehow show that the 'next branch is discared and
> reconstruced (from master) at the next release..
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/49a9bd88/attachment.sig>
