[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 14:03:17 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Should the “Testing/Users” arrow go all the way down next to the
> next line? Now it looks like maybe it means the testing/users is on
> the typical feature branch.
Changed.
>   The other thing that “bothers” me is the two arrows coming from the
>   last circle of a branch; one goes “straight” to next which is fine
>   but the other one goes “straight” to master. I think it would be
>   clearer if instead that second curve followed the branch line and
>   then quickly curved up to master. I have shared a stunningly crude
>   way of doing this (not I don’t intend to have the “bumb” in the
>   curve I just suck at drawing it.) This still conveys the fact that
>   the data for both next and master comes from the same circle but
>   makes it clearer that the data is not “moved” from the final circle
>   to master until later then it is moved to next; in fact it is not
>   moved from the branch until it gets into master. Hopefully you can
>   do that shape better then I.
Hmm, I like showing that after 'next' is rewound, the graph contains no
knowledge of 'next' integration (apart from stability).  What I want to
communicate is that the DECISION to merge to master is based on EVIDENCE
obtained from the integration in 'next'.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/3e96314f/attachment.sig>
