[petsc-dev] [petsc-maint] problem installing petsc 3.4
Jed Brown jed at jedbrown.org
Wed Apr 16 19:26:57 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>   In an ideal world compilers would have a standard, extensible API.
>   For years I’ve dreamed of day when Unix would be replaced with a
>   modern operating system where there would be a one-to-one mapping
>   between the C-lib interface to everything, the command line
>   interface to everything and the python API to everything. And two of
>   the three would be (largely) auto generated from the other.
Me, I spend my days dancing with unicorns in fields of golden poppies at
the end of the rainbow.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/0d3efd1d/attachment.sig>
