[petsc-dev] Experimental GNU make build system
Wed May 29 08:33:07 CDT 2013
Why pass it to the linker?
On May 29, 2013 8:32 AM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Wed, May 29, 2013 at 9:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 28 May 2013, Satish Balay wrote:
>> > Yet to check:
>> > - configure check for '-MMD -MP' stuff..
>> I see there is already a configure test for this in
>> config/BuildSystem/config/compilers.py using -with-dependencies=1
>> [default] - but no makefile flag is set.
> Thats fine.
>> So perhaps the following fix? [in balay/gmake-config-dpecheck]
>> https://bitbucket.org/petsc/petsc/commits/ee7bb8786b51b19508b610eb8895baeeae528351
>> Matt, BTW: does this thing have to do a link test using -MMD?
>> [Shouldn't it be a compile only test?]
> This is to make sure the flag does not screw up links.
>    Matt
>> thanks,
>> Satish
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130529/1b3ea20f/attachment.html>
