[petsc-dev] Experimental GNU make build system
Wed May 29 08:24:44 CDT 2013
On Wed, May 29, 2013 at 9:00 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 28 May 2013, Satish Balay wrote:
> > Yet to check:
> > - configure check for '-MMD -MP' stuff..
> I see there is already a configure test for this in
> config/BuildSystem/config/compilers.py using -with-dependencies=1
> [default] - but no makefile flag is set.
Thats fine.
> So perhaps the following fix? [in balay/gmake-config-dpecheck]
> https://bitbucket.org/petsc/petsc/commits/ee7bb8786b51b19508b610eb8895baeeae528351
> Matt, BTW: does this thing have to do a link test using -MMD?
> [Shouldn't it be a compile only test?]
This is to make sure the flag does not screw up links.
   Matt
> thanks,
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130529/b3559fe7/attachment.html>
