[petsc-dev] Experimental GNU make build system
Tue May 28 14:37:50 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Also pushed the following to 'jed/gnumake'
> commit 98a400349847cf14d7f7ce4945a32c59fde5e766
> Author: Satish Balay <balay at mcs.anl.gov>
> Date:   Tue May 28 12:59:16 2013 -0500
>     gmake: add --with-shared-libraries=0 mode
I force-pushed my own version of this (that works
with-single-library=0).  The only difference in the overlap was use of
FAST_AR_FLAGS vs AR_FLAGS.  Is that safe/correct in general when
creating the entire archive in one shot, as opposed to incrementally?  I
also delete the old archive if it existed, before running AR again.
> Yet to check:
> - LOCDIR/SDIR stuff
Removing this would let us delete a bunch of code.  Was my suggestion
for using the full source names sufficient?
> - configure check for '-MMD -MP' stuff..
