[petsc-dev] Experimental GNU make build system
Thu May 23 17:40:51 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> This issue is now fixed in cygwin dll [snapshot].
> http://cygwin.com/ml/cygwin/2013-05/msg00342.html
> http://cygwin.com/ml/cygwin/2013-05/msg00348.html
Does this mean we shouldn't bother with a work-around, or we should have
configure test whether the bug exists and work around it only when
necessary?
