[petsc-dev] Experimental GNU make build system
Thu May 23 14:04:58 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> > Hm - that might mean all variants here - 'win32fe', 'ar' etc have to support the @cmdfile notation?
>> FWIW, 'ar' does support @file.  So if the problem is deeper, than may
>> still be a good option.
> Looks like win32fe isn't passing in @cmdfile option.
> BTW: one issue with @file option - If I remember correctly: there is
> some length limit to options listed here. [It prefers options split
> across multiple lines - rather than a single big line]. But perhaps
> gnumake's support of this feature takes care of that problem.
This looks funny, but will work:
  $(file >$@.args,)                       # Truncate the file
  $(foreach O, $^, $(file >> $@.args,$O)) # Append lines
