[petsc-dev] Experimental GNU make build system
Thu May 23 13:50:03 CDT 2013
On Thu, 23 May 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > Hm - that might mean all variants here - 'win32fe', 'ar' etc have to support the @cmdfile notation?
> FWIW, 'ar' does support @file.  So if the problem is deeper, than may
> still be a good option.
Looks like win32fe isn't passing in @cmdfile option.
BTW: one issue with @file option - If I remember correctly: there is
some length limit to options listed here. [It prefers options split
across multiple lines - rather than a single big line]. But perhaps
gnumake's support of this feature takes care of that problem.
Satish
