[petsc-dev] Experimental GNU make build system
Mon May 20 20:51:48 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>   And does this solve the Windows problem?
Not tested on Windows.  It might work with mingw, but mingw seems to be
something that a packager uses to create binaries rather than something
a user sets up.  I think we should normalize and namespace all the
variables in $PETSC_ARCH/conf/petscvariables.  It's quite inconsistent
now, so it's tricky to keep all build systems in sync.
