[petsc-dev] Experimental GNU make build system
Mon May 20 20:22:03 CDT 2013
  And does this solve the Windows problem?
On May 20, 2013, at 4:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I just merged 'jed/gnumake' to 'next'.  I haven't added support for
> static libraries yet, but it should work with pretty much all other
> configurations using compilers that support '-MMD -MP' (tested with gcc,
> clang, and intel; C, C++, and Fortran; single and multiple library).
>  $ make -f gmakefile -j20 PETSC_ARCH=your-choice
> The makefile is 100 lines and the Python for figuring out what to
> include in the build is about the same (conf/gmakegen.py; neglecting
> python-2.4 compatibility stuff).  Simplifying the rules would reduce
> that, naturally.
> Let me know how it works for you.
