[petsc-dev] Propose a change for PetscObjectDestroyOptionsHandlers()
Tue May 14 07:26:17 CDT 2013
Please use reply-all so the response includes the list, in case anyone
else is following this.
Lisandro Dalcin <dalcinl at gmail.com> writes:
>>> PetscObjectDestroyOptionsHandlers() do not check if the registered
>>> destroy routine is NULL. In general, the destroy routines are
>>> optional. Should we fix this in maint?
>> Yes, does this break something now?  It is not used by anything in
>> PETSc, petsc4py, SLEPc, or TAO, so hopefully it's not an urgent fix.
> No, it is not urgent. But I wanted to ask ASAP before I forget. So I'm
> goint to make a PR to maint. Thanks.
Great.
