[petsc-dev] Propose a change for PetscObjectDestroyOptionsHandlers()
Tue May 14 06:13:48 CDT 2013
Lisandro Dalcin <dalcinl at gmail.com> writes:
> PetscObjectDestroyOptionsHandlers() do not check if the registered
> destroy routine is NULL. In general, the destroy routines are
> optional. Should we fix this in maint?
Yes, does this break something now?  It is not used by anything in
PETSc, petsc4py, SLEPc, or TAO, so hopefully it's not an urgent fix.
