[petsc-dev] testing: with parmetis, without 64-bit, without complex
Mon May 13 14:23:12 CDT 2013
On Mon, May 13, 2013 at 1:08 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >   a) Switch the nightlies from make to Python
> Are you talking about compilation or running tests?  Compilation should
> be irrelevant because all systems should produce the same result.  I
> think testing is higher priority.
Running and interpreting.
   Matt
> >   b) Change the categories to tags
> Yeah, just can't do this within the current make-based running system.
> >   c) Simply parse parts of the output for numerical comparison
> It's useful to compare everything because otherwise, new clutter can
> show up unintentionally and won't be caught by testing.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130513/52b594b8/attachment.html>
