[petsc-dev] testing: with parmetis, without 64-bit, without complex
Mon May 13 12:45:38 CDT 2013
   I am fine with just totally removing this outdated example
   Barry
On May 13, 2013, at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> src/vec/is/ao/examples/tutorials/ex2.c fails because it was not written
> to use the typedefs.
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/examples_master_arch-linux-pkgs-64idx_thrash.log
> Expressing this set of configuration constraints is a total mess in the
> current system.  Should we just remove it from the nightlies entirely?
> Or have it #error or compilation when attempting to use a broken
> configuration (so the test error is understandable)?
> The example is also in the wrong place: it depends on Mat, so it cannot
> be in src/vec/.
