[petsc-dev] release naming scheme
Fri May 10 22:41:55 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Perhaps this was partly discussed in various threads.
> With the new release Jed suggested that we go with the standard
> release naming convention and switching patch updates from
> PETSC_VERSION_PATCH to PETSC_VERSION_SUBMINOR.
> [I'm fine with this change but want to discuss a bit more]
> The new release numbers would be:
> petsc-3.4.0 [or should this be petsc-3.4 - like http://mercurial.selenic.com/release/?C=M;O=D ]
I would be fine with either.  Maybe "petsc-3.4" will give a stronger
impression that the minor version defines the interface, so that
upgrading subminor versions is comfortable?
> petsc-3.4.1
> petsc-3.4.2
> etc
> And then:
> petsc-3.5.0
> petsc-3.5.1
> etc..
> Currently we have PETSC_VERSION_PATCH & PETSC_VERSION_PATCH_DATE for
> representing the patch releases.
> We would have to remove PETSC_VERSION_PATCH - and change
> PETSC_VERSION_PATCH_DATE to PETSC_VERSION_SUBMINOR_DATE?
What is the utility of PETSC_VERSION_PATCH_DATE?
I might leave PETSC_VERSION_PATCH defined to 0, reserved for packagers
to use if they decide to backport features or bug fixes.  In any case, I
think that leaving it defined doesn't hurt anything, and will make more
scripts continue to work.
> [and some of these scripts would need fixing to work with this change]
> Satish
> $ git grep PETSC_VERSION_PATCH
> bin/maint/builddist:version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
> bin/maint/builddist:#add in PETSC_VERSION_PATCH_DATE and PETSC_VERSION_GIT
> bin/maint/builddist:echo Using PETSC_VERSION_PATCH_DATE: ${version_patch_date}
> bin/maint/builddist:  sed -e "s/#define PETSC_VERSION_PATCH_DATE.*/#define PETSC_VERSION_PATCH_DATE \"${version_patch_date}\"/" | \
> bin/maint/createpatch:version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
> bin/maint/createpatch:  sed -e "s/#define PETSC_VERSION_PATCH .*/#define PETSC_VERSION_PATCH      ${new_version_patch}/" > include/petscversion.h
> bin/maint/rebuildtar:PATCH_VERSION=`grep '^#define PETSC_VERSION_PATCH ' ${PETSC_DIR}/include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
> bin/maint/submitPatch.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
> bin/maint/submitPatch.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
> bin/petscnagupgrade.py:    patchversion = int(re.compile(' PETSC_VERSION_PATCH[ ]*([0-9]*)').search(pv).group(1))
> bin/petscnagupgrade.py:    apatchversion = int(re.compile(' PETSC_VERSION_PATCH[ ]*([0-9]*)').search(pv).group(1))
> config/BuildSystem/config/packages/PETSc.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
> config/BuildSystem/config/packages/PETSc.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
> config/PETSc/petsc.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
> config/PETSc/petsc.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
> include/petscversion.h:#define PETSC_VERSION_PATCH_DATE "unknown"
> makefile:        version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`; \
> setup.py:        'patch'  : re.compile(r"#define\s+PETSC_VERSION_PATCH\s+(\d+)"),
> src/sys/objects/version.c:  ierr = PetscSNPrintf(version,len,"Petsc Release Version %d.%d.%d, Patch %d, %s ",PETSC_VERSION_MAJOR,PETSC_VERSION_MINOR, PETSC_VERSION_SUBMINOR,PET
