[petsc-dev] release naming scheme
Fri May 10 22:29:24 CDT 2013
Perhaps this was partly discussed in various threads.
With the new release Jed suggested that we go with the standard
release naming convention and switching patch updates from
PETSC_VERSION_PATCH to PETSC_VERSION_SUBMINOR.
[I'm fine with this change but want to discuss a bit more]
The new release numbers would be:
petsc-3.4.0 [or should this be petsc-3.4 - like http://mercurial.selenic.com/release/?C=M;O=D ]
petsc-3.4.1
petsc-3.4.2
etc
And then:
petsc-3.5.0
petsc-3.5.1
etc..
Currently we have PETSC_VERSION_PATCH & PETSC_VERSION_PATCH_DATE for
representing the patch releases.
We would have to remove PETSC_VERSION_PATCH - and change
PETSC_VERSION_PATCH_DATE to PETSC_VERSION_SUBMINOR_DATE?
[and some of these scripts would need fixing to work with this change]
Satish
$ git grep PETSC_VERSION_PATCH
bin/maint/builddist:version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
bin/maint/builddist:#add in PETSC_VERSION_PATCH_DATE and PETSC_VERSION_GIT
bin/maint/builddist:echo Using PETSC_VERSION_PATCH_DATE: ${version_patch_date}
bin/maint/builddist:  sed -e "s/#define PETSC_VERSION_PATCH_DATE.*/#define PETSC_VERSION_PATCH_DATE \"${version_patch_date}\"/" | \
bin/maint/createpatch:version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
bin/maint/createpatch:  sed -e "s/#define PETSC_VERSION_PATCH .*/#define PETSC_VERSION_PATCH      ${new_version_patch}/" > include/petscversion.h
bin/maint/rebuildtar:PATCH_VERSION=`grep '^#define PETSC_VERSION_PATCH ' ${PETSC_DIR}/include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`
bin/maint/submitPatch.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
bin/maint/submitPatch.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
bin/petscnagupgrade.py:    patchversion = int(re.compile(' PETSC_VERSION_PATCH[ ]*([0-9]*)').search(pv).group(1))
bin/petscnagupgrade.py:    apatchversion = int(re.compile(' PETSC_VERSION_PATCH[ ]*([0-9]*)').search(pv).group(1))
config/BuildSystem/config/packages/PETSc.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
config/BuildSystem/config/packages/PETSc.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
config/PETSc/petsc.py:    patchRE    = re.compile(r'^#define PETSC_VERSION_PATCH([\s]+)(?P<patchNum>\d+)[\s]*$');
config/PETSc/petsc.py:        lines.append('#define PETSC_VERSION_PATCH'+m4.group(1)+str(patchNum)+'\n')
include/petscversion.h:#define PETSC_VERSION_PATCH_DATE "unknown"
makefile:        version_patch=`grep '^#define PETSC_VERSION_PATCH ' include/petscversion.h |tr -s ' ' | cut -d ' ' -f 3`; \
setup.py:        'patch'  : re.compile(r"#define\s+PETSC_VERSION_PATCH\s+(\d+)"),
src/sys/objects/version.c:  ierr = PetscSNPrintf(version,len,"Petsc Release Version %d.%d.%d, Patch %d, %s ",PETSC_VERSION_MAJOR,PETSC_VERSION_MINOR, PETSC_VERSION_SUBMINOR,PET
