[petsc-dev] Any substitute for -ts_theta_adapt
Wed May 8 08:41:55 CDT 2013
Lulu Liu <lulu.liu at kaust.edu.sa> writes:
> I want to register a new adaptive time-step  scheme for the backward Euler
> method.  I used   options:
>  -ts_adapt_type myscheme   -ts_theta_adapt
> The error message is show as:
> No time-step adaptivity implemented for 1st order theta method;
Please show the full error trace.  Presumably you are calling
TSEvaluateStep, but if you are trying to step with a first-order method,
you can't use "zeroth order" as an estimate of the error.
> Is there any substitute for -ts_theta_adapt such that I could have my own
> time-step adaptivity for backward Euler?
Why not use '-ts_type arkimex -ts_arkimex_type 1bee', which uses an
extrapolation-based error estimator?  If you want something else, just
write it as a Runge-Kutta method like '1bee'.
