[petsc-dev] Any substitute for -ts_theta_adapt
Lulu Liu lulu.liu at kaust.edu.sa
Wed May 8 08:31:02 CDT 2013
I want to register a new adaptive time-step  scheme for the backward Euler
method.  I used   options:
 -ts_adapt_type myscheme   -ts_theta_adapt
The error message is show as:
No time-step adaptivity implemented for 1st order theta method;
Is there any substitute for -ts_theta_adapt such that I could have my own
time-step adaptivity for backward Euler?
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130508/b853d0d0/attachment.html>
