[petsc-dev] CMake-assisted CUDA builds ready
Karl Rupp rupp at mcs.anl.gov
Tue Mar 26 15:08:15 CDT 2013
Hi again,
thanks, I think I could eliminate the cause.
Please give 'next' another try...
Thanks and best regards,
Karli
On 03/26/2013 11:28 AM, Jose E. Roman wrote:
> El 26/03/2013, a las 17:27, Karl Rupp escribió:
>> Hi Jose,
>> which host compiler do you use? nvcc seems to have problems with double-quoted flags such as " -O -arch=sm_13 ".
>> Karli
> $ nvcc -V
> nvcc: NVIDIA (R) Cuda compiler driver
> Copyright (c) 2005-2012 NVIDIA Corporation
> Built on Thu_Apr__5_00:24:31_PDT_2012
> Cuda compilation tools, release 4.2, V0.2.1221
> $ gcc -v
> Using built-in specs.
> Target: x86_64-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.4.3-4ubuntu5.1' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --program-suffix=-4.4 --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i486 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
> Thread model: posix
> gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5.1)
