[petsc-dev] CMake-assisted CUDA builds ready
Jose E. Roman jroman at dsic.upv.es
Tue Mar 26 11:28:44 CDT 2013
El 26/03/2013, a las 17:27, Karl Rupp escribió:
> Hi Jose,
> which host compiler do you use? nvcc seems to have problems with double-quoted flags such as " -O -arch=sm_13 ".
> Thanks and best regards,
> Karli
$ nvcc -V
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2012 NVIDIA Corporation
Built on Thu_Apr__5_00:24:31_PDT_2012
Cuda compilation tools, release 4.2, V0.2.1221
$ gcc -v
Using built-in specs.
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 4.4.3-4ubuntu5.1' --with-bugurl=file:///usr/share/doc/gcc-4.4/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.4 --program-suffix=-4.4 --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-plugin --enable-objc-gc --disable-werror --with-arch-32=i486 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5.1)
