[petsc-dev] patches for ICC/Cholesky preconditioner on GPUs
Paul Mullowney paulm at txcorp.com
Sun Mar 24 15:17:14 CDT 2013
Jed,
I think I've resolved all of your comments. I have some questions.
1) Tests for the nightly test harness
(a) Is there a naming convention for the tests?
I have written two examples named aijcusparse_ex_ilu.c and
aijcusparse_ex_icc.c. Is this ok?
(b) What directory should they live in?
I assume these go in ksp/ksp/examples/tutorials
(c) How do I ensure that they tests are built and run every night with
txpetscgpu package?
(d) Where do I put binary matrix files that these tests rely upon?
2) Doing
 > git status
shows
     Your branch is ahead of 'origin/pm/aijcusparse-icc' by 2 commits.
I assume that when I push to the fork, these changes will be uploaded
remotely?
-Paul
> Paul Mullowney<paulm at txcorp.com>  writes:
>> Hi,
>> I've gotten GPU based icc preconditioners working with the following set
>> of patches. One uses ICC by loading an upper triangular matrix into the
>> cusparse class, and then setting the symmetry option, i.e.
>>       ierr =
>> MatCreateSeqAIJCUSPARSE(comm,n,m,PETSC_NULL,num_entries_per_row,&A);CHKERRQ(ierr);
>>       ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);
>> I've organized the implementations into 2 files:
>> 1) icc-cholesky-cusparse-organization.patch : This patch has the basic
>> infrastructure for calling the symbolic and numeric factorizations (both
>> ICC and Cholesky). Currently these routines make scoping calls to the
>> implementations in aij/seq/aijfact.c
> Can you write context like this into the commit messages? They are
> pretty opaque right now, but they are more likely to be read in the
> future than this email.
> This patch series does not have any tests. Can you add tests so that we
> can have a reasonable chance of not breaking it in the future?
> We can review on the mailing list, but I think we would prefer to use
> pull requests, mostly because comments there sort by context rather than
> by author. Barry, Matt, and others, do you prefer the granularity of
> email or bitbucket comments?
> A few comments now:
>> exporting patch:
> This first line should not be in the patch file. It should start with the lines below:
>> # HG changeset patch
>> # User Paul Mullowney<paulm at txcorp.com>
>> # Date 1362859983 25200
>> # Node ID 6be0d0f06ad18794377015b5ec468e11105b58b1
>> # Parent  6d60df3aadfe49f0bf640fa0a41fe3a423b88cf6
>> Implementation of ICC in this patch.
> Include the component (aijcusparse) in the commit message, otherwise we
> don't have a clue from the commit message what is actually being done.
>> diff -r 6d60df3aadfe -r 6be0d0f06ad1 src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu
>> --- a/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu	Mon Feb 04 11:42:47 2013 -0700
>> +++ b/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu	Sat Mar 09 13:13:03 2013 -0700
>> @@ -1,12 +1,13 @@
>> -    Defines the basic matrix operations for the AIJ (compressed row)
>> +  Defines the basic matrix operations for the AIJ (compressed row)
>>     matrix storage format.
>>   #include "petscconf.h"
>>   PETSC_CUDA_EXTERN_C_BEGIN
>>   #include "../src/mat/impls/aij/seq/aij.h"          /*I "petscmat.h" I*/
>> -//#include "petscbt.h"
>> +#include<../src/mat/impls/sbaij/seq/sbaij.h>
>>   #include "../src/vec/vec/impls/dvecimpl.h"
>>   #include "petsc-private/vecimpl.h"
>>   PETSC_CUDA_EXTERN_C_END
> Not part of this patch, but PETSC_CUDA_EXTERN_C_BEGIN/END should be
> replaced with appropriate use of PETSC_EXTERN (as shown below). We are
> no longer mangling any public function names, so we can now compile
> PETSc using --with-clanguage=C++ and then call it from plain C.
>> @@ -53,12 +54,28 @@
>>   EXTERN_C_BEGIN
>>   extern PetscErrorCode MatGetFactor_seqaij_petsc(Mat,MatFactorType,Mat*);
>>   EXTERN_C_END
> Use this instead:
> PETSC_EXTERN PetscErrorCode MatGetFactor_seqaij_petsc(Mat,MatFactorType,Mat*);
>> @@ -404,12 +417,119 @@
> Isn't this a lot of blank lines?
>> +#undef __FUNCT__
>> +#define __FUNCT__ "MatSeqAIJCUSPARSEBuildICCTriMatrices"
>> +PetscErrorCode MatSeqAIJCUSPARSEBuildICCTriMatrices(Mat A)
> Please use 'static' if the function is really only used in this one
> file. This identifier is more than 31 characters, thus too long for a
> public symbol.
>> +  Mat_SeqAIJ                   *a                  = (Mat_SeqAIJ*)A->data;
>> +  Mat_SeqAIJCUSPARSETriFactors *cusparseTriFactors = (Mat_SeqAIJCUSPARSETriFactors*)A->spptr;
>> +  GPU_Matrix_Ifc               * cusparseMatLo       = (GPU_Matrix_Ifc*)cusparseTriFactors->loTriFactorPtr;
>> +  GPU_Matrix_Ifc               * cusparseMatUp       = (GPU_Matrix_Ifc*)cusparseTriFactors->upTriFactorPtr;
> Either line up consecutive lines or don't, but don't go half way. PETSc
> style guide says 'type *ptr', not 'type * ptr'.
>> +  cusparseStatus_t             stat;
>> +  PetscErrorCode               ierr;
>> +  PetscInt                     *AiUp, *AjUp;
>> +  PetscScalar                  *AAUp;
>> +  PetscScalar                  *AALo;
>> +  PetscInt          nzUpper=a->nz,n=A->rmap->n,i,offset,nz,j;
>> +  Mat_SeqSBAIJ      *b = (Mat_SeqSBAIJ*)A->data;
>> +  const PetscInt    *ai=b->i,*aj=b->j,*vj;
>> +  const MatScalar   *aa=b->a,*v;
> Again, line up or don't line up.
>> +      /* set this flag ... for performance logging */
>> +      ((Mat_SeqAIJCUSPARSETriFactors*)A->spptr)->isSymmOrHerm = PETSC_TRUE;
> Does this have a MatSetOption() interface?
>>   #undef __FUNCT__
>>   #define __FUNCT__ "MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU"
>>   PetscErrorCode MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU(Mat A)
> This can have static linkage, right?
>> @@ -706,8 +848,28 @@
>>         ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> [Different patch] PETSC_COMM_WORLD cannot be used outside of global
> registration.
