[petsc-dev] PTScotch 6
Tue Mar 19 11:56:24 CDT 2013
> > On Tue, 19 Mar 2013, Jed Brown wrote:
> > > No, we would apply the patch in 'maint' and merge the branch directly to
> > > 'next'. Later, we merge the same branch into 'maint'.
> > I don't understand this. you mean 'master' at the end? So you mean:
> > - create a 'patch' branch off 'maint' and apply this patch.
> > - merge this 'patch' branch to 'maint'
> > - merge this 'patch' branch to 'next'
> > - merge thsi 'patch' branch to 'master'
> > or something else?
> Or perhaps you mean 'you create a branch off maint - and apply this
> patch and merge this branch ...'
> If so - how will the patch get into master? Previously all 33 stuf
> landed in dev with direct pull.  Same workflow or different here?
> with new workflow all 'master' gets merged periodically to 'next' - so
> same periodic merge from 'maint' to 'master'?
A couple of follow-on questions for this.
Should one create remote branches for all such branches?
How does one keep track of the 'merge path' the branch is destined to?
One kows this before the branch is create and then remembers it until
it gets merged to all its destinations? [or use some complicated git
commands to keep track of this?]
thanks,
Satish
