[petsc-dev] PTScotch 6
Tue Mar 19 10:57:41 CDT 2013
On Tue, Mar 19, 2013 at 10:52 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> I guess this is not so important to fix in 3.3.
Yeah, we don't normally include include new feature-releases of external
packages in maintenance releases. In that case, the branch can start at
'master'.
> They have separated the sequential and parallel versions. From file
> INSTALL.txt:
>   Since version 6.0, the Scotch and PT-Scotch packages can be made
>   independent. The libScotch will not be tied by any dependency against
>   any MPI package, while the libPTScotch has to depend on the one with
>   which it has been compiled, in addition to the libScotch package that
>   it uses.
>   In versions 5.x, the libPTScotch also contained a modified copy of the
>   libScotch. It is no longer the case, which will result in lower disk
>   footprint.
Okay, this is much more sane.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130319/8d0d88e0/attachment.html>
