[petsc-dev] PTScotch 6
Jose E. Roman jroman at dsic.upv.es
Mon Mar 18 12:35:42 CDT 2013
There is a new version of PTScotch. I tried configuring with --download-ptscotch=https://gforge.inria.fr/frs/download.php/31832/scotch_6.0.0_esmumps.tar.gz
It works on Linux with the patch below (note the missing whitespace should have been fixed in 3.3).
On Mac I had a compilation problem related to pthreads. After commenting out these lines in PTScotch.py it builds well.
    if self.libraries.add('-lpthread','pthread_key_create'):
      self.cflags = self.cflags + ' -DCOMMON_PTHREAD'
      ldflags += ' -lpthread'
Jose
diff -r 19e6251ff91d config/PETSc/packages/PTScotch.py
--- a/config/PETSc/packages/PTScotch.py	Thu Mar 14 20:16:54 2013 -0500
+++ b/config/PETSc/packages/PTScotch.py	Mon Mar 18 18:29:11 2013 +0100
@@ -6,7 +6,7 @@
     #'https://gforge.inria.fr/frs/download.php/28978/scotch_5.1.12b_esmumps.tar.gz'
     self.download     = ['http://ftp.mcs.anl.gov/pub/petsc/externalpackages/scotch_5.1.12b_esmumps-p1.tar.gz']
     self.downloadfilename = 'scotch'
-    self.liblist      = [['libptesmumps.a', 'libptscotch.a','libptscotcherr.a']]
+    self.liblist      = [['libptscotch.a','libptscotcherr.a','libscotch.a','libscotcherr.a']]
     self.functions    = ['SCOTCH_archBuild']
     self.includes     = ['ptscotch.h']
     self.requires32bitint = 0
@@ -56,7 +56,7 @@
     if self.libraries.add('-lm','sin'): ldflags += ' -lm'
     if self.libraries.add('-lrt','timer_create'): ldflags += ' -lrt'
-    self.cflags = self.cflags + '-DCOMMON_RANDOM_FIXED_SEED'
+    self.cflags = self.cflags + ' -DCOMMON_RANDOM_FIXED_SEED'
     # do not use -DSCOTCH_PTHREAD because requires MPI built for threads.
     self.cflags = self.cflags + ' -DSCOTCH_RENAME -Drestrict="" '
     # this is needed on the Mac, because common2.c includes common.h which DOES NOT include mpi.h because
