[petsc-dev] Build error in Cygwin
Chen Shapira chen2600 at gmail.com
Mon Mar 18 09:10:29 CDT 2013
I understand now,
Thanks
Chen
On Mon, Mar 18, 2013 at 3:48 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Mar 18, 2013 at 8:41 AM, Chen Shapira <chen2600 at gmail.com> wrote:
>> the error message told me to download the regular petsc copy,
>> I need the petsc-dev copy (which I've obtained from bitbucket , as the
>> official petsc web-instructions said)
> That repository has all the development, see here:
> https://bitbucket.org/petsc/petsc/wiki/Home
> The 'master' branch is a (hopefully) more stable form of what used to be the
> petsc-dev repository, and will become the next release. The 'next' branch
> also has some experimental or incomplete features.
>> On Mon, Mar 18, 2013 at 3:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > Do what the error message says.
>> > On Mar 18, 2013 8:18 AM, "Chen Shapira" <chen2600 at gmail.com> wrote:
>> >> Hi ,
>> >> I'm building petsc in cygwin , and
>> >> when running my configure command :
>> >> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
>> >> --with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
>> >> (x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
>> >> --with-petsc-arch=arch-mswin-c-debug
>> >> --CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
>> >> --ignore-cygwin-link --with-valgrind=0 --with-c2html=0
>> >> --download-sowing=1 --with-hdf5=1
>> >> --with-hdf5-include=/cygdrive/c/libraries/hdf5/include
>> >> --with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,
>> >> /cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
>> >> I get the following message (in cygwin) :
>> >>   The PETSc development repository has moved. The new repository can be
>> >>   cloned using:
>> >>     $ git clone https://bitbucket.org/petsc/petsc
>> >>   or, using the Mercurial mirror:
>> >>     $ hg clone https://bitbucket.org/petsc/petsc-hg
>> >>   See the website for further details:
>> >> Could someone tell me how to continue ?
>> >> I've downloaded petsc-dev and its buildsystem using : hg clone
>> >> https://bitbucket.org/petsc/petsc-dev
>> >> Please let me know how can I built it
>> >> Thanks
