[petsc-dev] refactoring petsccusp.h needed
Karl Rupp rupp at mcs.anl.gov
Sat Mar 16 07:50:45 CDT 2013
Hi Jose,
>> Since I just stumbled over VecMDot_SeqCUSP() when interfacing ViennaCL: Do you know what was the reason why the 'old' version was replaced by this expensive call to gemv() including the creation of temporaries, etc.? Just writing a custom kernel with one work group per dot-product should do the job perfectly, shouldn't it?
> My fault: https://bitbucket.org/petsc/petsc-hg/commits/ec7a7de2acd477e5edd24cc5a3af441ce7a68a36
> The motivation was that the previous version was even worse for me (VecMDot is used a lot in SLEPc and GPU performance was really bad). At that time I did not have the time to write a custom kernel. If you write one, I could help in testing and measuring performance.
Thanks for providing the context. It makes sense to me now, because for
eigenvalue computations you typically have a lot more vectors taking
part in mdot as compared to GMRES. This looks like an archetypal example
for using two different kernels: The first is suitable for 'small'
numbers of vectors (GMRES), while the second is more gemv-like and good
for larger vector counts (SLEPc). I'll let you know as soon as it's
ready for testing.
Thanks and best regards,
Karli
