[petsc-dev] PETSc repositories have been moved
Tue Mar 12 16:01:24 CDT 2013
On Tue, Mar 12, 2013 at 4:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 12, 2013, at 3:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Tue, Mar 12, 2013 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Mar 12, 2013, at 2:52 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> > > Hi Richard,
> > > Jed and I set up detailed instructions on how to use Git and Mercurial:
> > > https://bitbucket.org/petsc/petsc/wiki/Home
> >   Note that both Karl and Jed know git very well, so these pages will
> pretty much suck for new users.
> > I agree. That is why its important that its a Wiki.
>    Because you perceive a Wiki as something that is very easy to change
> something in quickly.  I think in that sense Wikis are like PERL, it is
> very quick to put something together that looks powerful, but long term
> maintenance and general extension is impossible. Why not put all PETSc
> source code into the wiki then we can easily edit it without bothering with
> Emacs and shells?
I think Wikis are good because the build system is right there. No
monkeying with LaTeX+latex2html/Sphinx/DocBook/WhatEverCrazySystem. I can
see exactly what I put in right away, and so can everyone else. Its exactly
the same version control as the source, as Jed pointed out, and I have been
using them for other projects and its easy.
I think using one system for a manual (LaTeX) and one system for online
help (Wiki) is fine. In fact, the brain trust at PETSc Central
already does this since we have a FAQ and Function Manpages separate from
our manual.
   I am fine with putting that stuff there in the short term, but how about
> in the longer term having it as a subtree (subrepo?) in the petsc/src/docs/
>  directory?
Why would this be any different?
   Matt
>    Barry
> > I checked one thing in this morning.
> >   Matt
> >    Barry
> > > In short, to get your changes merged back 'upstream', you still just
> need to send a pull request for petsc-hg on Bitbucket. :-)
> > > Best regards,
> > > Karli
> > > On 03/12/2013 02:42 PM, Richard Tran Mills wrote:
> > >> Hi Barry,
> > >> I will start using Git for working with petsc-dev when there are some
> > >> clear instructions on the workflow we should be using.  In the
> meantime
> > >> I have some petsc-dev tasks on my to-do list and I plan to work using
> a
> > >> fork of petsc-hg.  To get my changes merged back "upstream", I assume
> I
> > >> still just need to submit a pull request for petsc-hg on BitBucket?
> > >> Thanks,
> > >> Richard
> > >> On 3/12/13 12:16 PM, Barry Smith wrote:
> > >>>    PETSc dev users,
> > >>>     The PETSc repositories have been moved. They are at
> > >>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
> > >>> (git version)
> > >>> https:/bitbucket.org/petsc/petsc-hg
> > >>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
> > >>> please reclone all your repositories and do not use the previous
> > >>> repository!
> > >>> You may make pull requests via bitbucket for either repository.   The
> > >>> Mecurial version is read only; active developers with write access
> > >>> will be working with the git version but the the Mecurial version
> will
> > >>> always be in sync with the master branch of the git version.
> > >>> Problems? Send email or bug one of Jed, Satish, Barry
> > >>>   Barry
> > >>> Begin forwarded message:
> > >>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:
> jedbrown at mcs.anl.gov>>
> > >>>> *Subject: **petsc-hg*
> > >>>> *Date: *March 12, 2013 10:20:51 AM CDT
> > >>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
> > >>>> https://bitbucket.org/petsc/petsc-hg/
> > >>>> This is currently writable only by me. It will mirror 'master' from
> > >>>> the Git repo and people can send pull requests to it.
> > >> Richard Tran Mills, Ph.D.
> > >> Computational Earth Scientist      | Joint Assistant Professor
> > >> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary
> Sciences
> > >> Oak Ridge National Laboratory      | University of Tennessee,
> Knoxville
> > >> E-mail:rmills at ornl.gov   V: 865-241-3198
> http://climate.ornl.gov/~rmills
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130312/84f4b520/attachment.html>
