[petsc-dev] PETSc repositories have been moved
Richard Tran Mills rtm at eecs.utk.edu
Tue Mar 12 14:42:11 CDT 2013
Hi Barry,
I will start using Git for working with petsc-dev when there are some
clear instructions on the workflow we should be using.  In the meantime I
have some petsc-dev tasks on my to-do list and I plan to work using a fork
of petsc-hg.  To get my changes merged back "upstream", I assume I still
just need to submit a pull request for petsc-hg on BitBucket?
Richard
On 3/12/13 12:16 PM, Barry Smith wrote:
>     PETSc dev users,
>      The PETSc repositories have been moved. They are at
> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
> (git version)
> https:/bitbucket.org/petsc/petsc-hg
> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
> please reclone all your repositories and do not use the previous
> repository!
> You may make pull requests via bitbucket for either repository.   The
> Mecurial version is read only; active developers with write access will
> be working with the git version but the the Mecurial version will always
> be in sync with the master branch of the git version.
> Problems? Send email or bug one of Jed, Satish, Barry
>    Barry
> Begin forwarded message:
>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
>> *Subject: **petsc-hg*
>> *Date: *March 12, 2013 10:20:51 AM CDT
>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>> https://bitbucket.org/petsc/petsc-hg/
>> This is currently writable only by me. It will mirror 'master' from the
>> Git repo and people can send pull requests to it.
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130312/36d3a07d/attachment.html>
