[petsc-dev] Commit collision/corruption?
Wed Mar 6 17:44:09 CST 2013
On Wed, 6 Mar 2013, Jed Brown wrote:
> On Wed, Mar 6, 2013 at 5:25 PM, Sean Farley <sean at mcs.anl.gov> wrote:
> > This right here is the most suspect part. The minute you start monkeying
> > around with private functions and whatnot, you are in the danger zone. I
> > will have a hard time believing this isn't a bug in gitifyhg. In fact, I
> > am willing to bet on it.
> This commit took place before anything else. Can you explain the
> zero-content files?
This is the clue that points to "commit" massaging/altering tools
[like "rebase" - that I refer to and "gitifyhg" that Sean is pointing
to] as the instigator. They don't do 'hg operation' on files - but do
internal commit metadata manipulation - that can result in such
"empty" diffs in commits.
Satish
> https://bitbucket.org/BarryFSmith/petsc-dev-simp/commits/de73c9a7d341d846b5e16a8d61a48242f0521c02
> Run 'hg export de73c9a7d341d846b5e16a8d61a48'. Note how they do not exist
> in the formatted patch. Why are they written into the commit?
