[petsc-dev] Internal and external symbols
Tue Mar 5 17:21:17 CST 2013
  Jed,
    Please don't make any other changes along this line for right now. I have to merge my changes (removal/improvement of EXTERN_C_BEGIN/END) everywhere and test on many combinations of c/c++, dynamic, split libraries and push before you can make more changes.  It is a little hairy.
On Mar 5, 2013, at 11:09 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> PETSC_INTERN_C is for functions with internal visibility that must use the `extern "C"` calling convention. Normally this is any symbol passed to a dynamic registration function.
    At times I've wanted to split the PETSc library into two (or more) parts. The "interface" library, that contains functions users call directly like KSPSetType(), KSPGMRESSetRestart() and the actual implementations, like KPSCreate_GMRES(), KSPGMRESSetRestart_GMRES(), these would be loaded dynamically.  Hence I've kept the dynamic registration functions as PETSC_EXTERN_C, not PETSC_INTERN_C.   This "may" be a way to handle different precisions, complexity in the same application also if we can figure out how to put each implementation (for different precision, complexity) in a separate dynamically loaded library and load several at a time (without symbol conflict).
   Barry
