[petsc-dev] why is there a #requirespackage 'PETSC_HAVE_PCBDDC'
Stefano Zampini stefano.zampini at gmail.com
Tue Mar 5 04:22:35 CST 2013
HI,
I extensively tested and used the BDDC/FETI-DP code on two different linux
clusters and on BlueGene/Q and it worked fine for me.
The example (src/ksp/ksp/examples/tutorials/ex59.c) needs to be adapted in
its LAPACK calls to get it working on BlueGene/Q; namely,  LAPACKsterf_
should be added to petscblaslapack header files (Jed, can you do this?).
Also, I remember that some time ago Jed experienced some runtime problems
with this example. Can you test it now? It should work.
Yes, the complex case is not yet supported; also, there is some additional
work to do to get it working with 64 bit indices.
Regarding PARMETIS dependency: now the code makes explicit calls to METIS
functions and uses METIS types. Using MatPartitioning interface is on my
todo list to remove such an explicit dependency.
In the dev repo, the BDDC/FETI-DP code is all contained in bddc.c; I have
an improved version on my laptop and on BlueGene/Q with source codes split
in different files (for BDDC, FETI-DP and the BDDCGraph structure which is
used to analyze the interface between subdomains) and with the 64 bit
indices issue solved, but I cannot push it because it contains an advanced
scaling operator (see e.g. p. 9 bottom at
http://cs.nyu.edu/csweb/Research/TechReports/TR2013-951/TR2013-951.pdf)
which I'm extensively using in my research. Also, the new code needs the
Colpack library to compute distance 1 coloring of graphs (there's a
preliminary version of interface to Colpack at
https://bitbucket.org/petsc/petsc-dev/issue/25/add-support-for-1-coloring-instead-of-only
In summary: I'm fine with you adding the guards for PARMETIS, reals and 64
bit indices. I'm the only developer of BDDC code in PETSc, and now I don't
have time to push changes since I mostly work on it in my spare time (and
now I don't have spare time.. Maybe by the end of March)
2013/3/5 Stefano Zampini <s.zampini at cineca.it>
> HI,
> Stefano
> 2013/3/5 Jed Brown <jedbrown at mcs.anl.gov>
>> On Mon, Mar 4, 2013 at 6:25 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> The makefile should be marked as not supporting complex
>>> > It was put into the repository mostly because we don't have a good
>>> system for supporting forks.\
>>>    I thought bitbucket now gives a system for handling forks?
>> Yeah, this was before we used bitbucket, but we still haven't established
>> a workflow conducive to supporting downstream forks.
>>> > It was off by default because the code was unstable and untested.
>>> There is an example now (src/ksp/ksp/examples/tutorials/ex59.c) so I think
>>> we can remove the --with-pcbddc option. Stefano, does this sound right to
>>> you?
>>>    Or it could be a good test example for a PETSc plugin repository?
>> Yes, either way. Stefano, if you feel it is reasonably stable, can you
>> remove the --with-pcbddc guard and put in the necessary restrictions
>> (#requirespackage 'PETSC_HAVE_PARMETIS', #requiresscalar real)?
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130305/accae0e2/attachment.html>
