[petsc-dev] Using DMPlexConstructGhostCells
Mon Mar 4 13:16:44 CST 2013
On Sun, Mar 3, 2013 at 10:23 PM, Garnet Vaz <garnet.vaz at gmail.com> wrote:
> Hi,
> I am trying to use the function DMPlexConstructGhostCells to create
> some ghost cell information. Like in ex11 of dev-tutorials I need to
> access the centroid of the boundary cell to compute the distance.
> Following the example I see the following being done:
> Line 2209: DMPlexConstructGhostCells(dm, NULL, &user->numGhostCells, &gdm);
> The documentation says that the label name could be auto generated.
> Hence I tried passing NULL as above. This does not seem to work. I am
I have fixed the documentation.
> working on a 2d triangulation created from Triangle and distributed
> using chaco with an overlap of 1.
What do you mean by not work? Is your mesh modified? You can check
using DMView(gdm, PETSC_VIEWER_STDOUT_WORLD).
     Matt
> Thanks.
> Regards,
> Garnet
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130304/24c0d47b/attachment.html>
