[petsc-dev] Deflated Krylov solvers for PETSc
Sat Mar 2 05:32:37 CST 2013
On Sat, Mar 2, 2013 at 1:17 AM, Jie Chen <jiechen at mcs.anl.gov> wrote:
> For the former case, you are not trying to squeeze one subdomain to one
> compute node, are you? Why is it memory limited?
That's what I had in mind. Yes, you can use subdomains much larger than one
process, but it's easy to use smaller subdomains, and then the Galerkin
coarse operator becomes somewhat sparse.
Is there a demonstration of deflation providing significant benefit for
problems that are _not_ amenable to multigrid?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130302/fcc4d5e2/attachment.html>
